The three amigos lights
Old May 17, 2012 | 02:32 AM
FlyingZebra34's Avatar
Ok I just finished flushing the brake fluid and I'll be doing it again after I do the seal swap on the ABS system. I also took the time to remove each caliper/rotor and clean the sensors and they were pretty badly covered in mud and muck from all over the county! I don't know how much of an impact that grime has on the system but it is all clean as a whistle now. I started it a few times and drove around a bit and so far no lights.
Also the fluid was dark red and I was able to replace 1 quart in the system, I don't know how much anyone else normally goes through doing the flush.
Old May 17, 2012 | 04:54 AM
2 quarts DOT4 - which should be clear, or close to it but some suppliers offer color which lets you know when it has gone thru the system on a flush. Be sure to use fresh, sealed containers. Open brake fluid stored on shelf in garage not such a good idea.
Old May 17, 2012 | 11:55 PM
Alright the brake fluid is now good to go and I cleaned a lot of gunk off my brake system. Now the 3 Lights don't come on when I start or drive the truck, only when I punch the brakes (not all the time). I'm really lost on this matter and still waiting for Falcon Works to send my parts.
majrmike
Jun 6, 2016 03:05 PM
Broken08
Jul 31, 2015 03:49 PM
Disco Fever12
Apr 16, 2015 08:23 PM
rbwdriven
May 26, 2010 09:35 AM
offroader
Jun 16, 2007 12:31 AM
