To "Throttle Body Heater Plate" or to "Bypass", that is the question!
Old Mar 15, 2015 | 04:01 PM
  #21
dusty1's Avatar
Might be able to tap in some pipe threads and screw a 1/4 " nipple in there, pretty easily
Old Mar 15, 2015 | 09:16 PM
  #22
USAroverman's Avatar
Originally Posted by mln01
You don't even need to connect the two loose ends. You can just stick a properly sized 1" bolt into the end of each hose and plug them. The coolant does not need to flow through the hoses.
X2 easiest and cleanest way in my opinion. Made it through the PA winter with no issues I noticed no difference with all the cold we have had.
Attached Thumbnails To "Throttle Body Heater Plate" or to "Bypass", that is the question!-tb-bypass.jpg
Old Mar 15, 2015 | 09:31 PM
  #23
Jnj's Avatar
Jnj
Putting two bolts in the hose side what do you do about the throttle body side? Leave them open or plug those as well? What's the best size bolts to use to plug the hoses? I just noticed my TB is seeping
Old Mar 16, 2015 | 05:43 AM
  #24
Left the TB side wide open, the only thing circulating through that thing now is air. The bolts I found in my junk pile, they are about an inch long and they fit tight inside the hose before the clamp is applied. I think that's all that matters. This method hasn't leaked a single drop of anti-freeze.
Old Mar 13, 2016 | 09:59 PM
  #25
Charlie_V's Avatar
I'm glad you said that. I used bolts and as I read the thread I was wondering WTH have I done?!
j.dstasio
May 10, 2021 11:33 AM
cimomd
Apr 3, 2015 04:41 AM
mln01
Feb 2, 2015 08:19 AM
wynhd
Nov 21, 2013 10:40 AM
humroot
Mar 21, 2008 01:55 PM
