throttle body leak
The new gasket comes with a new plate, and screws, for $30. Not sure if you can use RTV in leu of actual pieces, but here's the kit either way, genuine LR. GASKET KIT THROTTLE BODY P38A RANGE ROVER & DISCOVERY II, RNH761, MGM000010K - Rovers North - Classic Land Rover Parts
You can also bypass it, while waiting on repairs. Prevents ice up of throttle under certain conditions just above freezing. The temperature drops from air flow change on the throttle body surfaces, and really can happen above freezing.
Not much of an issue in land of the Mixmaster this month..
