throttle body leak
Old Sep 11, 2013 | 11:13 AM
dusty1's Avatar
Default throttle body leak
finally sprung a leak. it is at underside of throttle housing. it is from the marriage of that bottom inlet section. gasket.
question= do i really need a gasket or is homemade and rtv, okay?
question= what is that gasket called, if I need one?
THANK YOU
Old Sep 11, 2013 | 11:27 AM
ZGPhoto's Avatar
The new gasket comes with a new plate, and screws, for $30. Not sure if you can use RTV in leu of actual pieces, but here's the kit either way, genuine LR. GASKET KIT THROTTLE BODY P38A RANGE ROVER & DISCOVERY II, RNH761, MGM000010K - Rovers North - Classic Land Rover Parts
Old Sep 11, 2013 | 01:16 PM
You can also bypass it, while waiting on repairs. Prevents ice up of throttle under certain conditions just above freezing. The temperature drops from air flow change on the throttle body surfaces, and really can happen above freezing.
Not much of an issue in land of the Mixmaster this month..
Old Sep 11, 2013 | 01:34 PM
dusty1's Avatar
thanks Zack, I forget about those fancy RN diagrams. don't really need to name that part, just highlight the pictures.
thanks Buzz, cool, i didn't even consider bypass. that should tide me over. its not supposed to get to 100 today, so i will cross my fingers and hope for no freezing.
Old Sep 11, 2013 | 02:30 PM
Living where you do, you can by-pass the system and never look back.
Hook both hoses together with a small piece of copper pipe and you"l be set.
Old Sep 11, 2013 | 04:59 PM
slabrat's Avatar
I did that several years ago. Never looked back.
Old Sep 11, 2013 | 05:21 PM
dusty1's Avatar
now we're talking. in my book, less is better. if i'm not using it... i can't break it.
thanks
SenatorPerry
Jul 15, 2013 10:28 AM
RamblingMan
Mar 2, 2009 10:39 PM
david1289
Oct 28, 2008 12:24 PM
Luv2Disco
Oct 20, 2008 04:08 PM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
