Time for new tires! I have a few questions.
Old Jan 23, 2012 | 05:23 PM
kfx4001442's Avatar
Default Time for new tires! I have a few questions.
2000 Discovery II 130,000miles, completely stock. I have the 18 inch stock rims. I am in need of advice on which tires to buy. I know the stock size is 255/55 R18. Im considering going a little bigger in size in an attempt to maybe gear the truck a little higher(slightly I know), and also the stock size tires just look a little too small for the truck in my opinion(Toyota Tundra syndrome). 58MPH = 3,000RPM on a V8? Seems a little much to me... Z-71's make that speed at 1300 RPM's. Maybe a bigger tire would bring those RPMs down a little and save a little gas, because right now it seems to get the fuel milage of a tractor. I'm more intrested in a quiet and smooth ride than I am about off roading. AND as always... price is a big factor.
1. What is the biggest tire that will fit under the stock DII on 18's without rubbing?
2. What kinda effects will going a little bigger give me?
3 What tires do you reccomend?
Old Jan 23, 2012 | 06:06 PM
ebg18t's Avatar
Most of us that go to a larger tire end up losing mpg and low end torque (assuming stock gearing).
How are you using the truck? That will dictate tire options.
Old Jan 23, 2012 | 06:45 PM
kfx4001442's Avatar
I mainly just drive it on the highway. Durring the summer I do a little trailer pulling(atv and boat.) Im not talking bigger as in mud tire im talking biger as in road tire, for better ride and higher gearing.
Old Jan 23, 2012 | 09:03 PM
Big Jim Swade's Avatar
I just changed mine to Nitto Terra Grapplers in 255/60-18" and really like them. The are about 30" tall compared to the 29's I had before. I wouldn't go any larger without some lift though. I have't noticed any mpg difference.
Old Jan 23, 2012 | 09:08 PM
shultzie's Avatar
I also did the 255/60-18 and are very happy with them. I agree I wouldnt go any bigger.
Old Jan 24, 2012 | 07:58 AM
tee51397's Avatar
Also a member of the 255/60 club and agree no larger without a lift.
I swapped out steering stops for the shorter ones used with 16" wheels and had rubbing on the radius arm at full lock after I went to the 255/60s and had to adjust them out a bit.
Old Jan 24, 2012 | 08:58 AM
jafir's Avatar
Mine turns less than 3000 rpm at 70. Were you exagerating? Or perhaps you aren't in 4th gear?
Snafu / Disco Fries
Aug 2, 2015 12:36 PM
Vigo
May 29, 2015 06:55 AM
Spencerfitch
Jun 12, 2010 02:49 PM
davecason
Jan 27, 2008 07:38 PM
briman42487
Oct 14, 2007 09:47 AM
