Tires rubbing radius arms
Old Dec 9, 2018 | 07:19 PM
Ben Matheson's Avatar
Default Tires rubbing radius arms
Nearly stock size 18 inch tires.. rubbing radius arms. Is this an indication of some other problem?
Old Dec 12, 2018 | 08:13 PM
Llamasayswhat's Avatar
Did you just swap wheels? What is "nearly stock"?
Nothing wearing/aging out would cause that issue.
If the car didn't originally have 18s, the steering stops will be the wrong length to stop you from rubbing
You can adjust the steering stops out really easily. About 10 mins of work to spin them out a few turns and stop them from rubbing
Old Dec 13, 2018 | 09:48 AM
dgi 07's Avatar
True
Ehhhh that's 50-50
I went from 16's to 19's 5 years ago and have never rubbed a day. (L322a wheels)
OP, what is nearly stock and what wheels are you running?
Offset may be wrong.
Old Dec 13, 2018 | 09:53 AM
It's a 2004 running original 18inch wheels I put on new falken wildpeaks in 265 vs stock 255 size. Tires are marginally wider so I was surprised to have them touch the arms
Old Dec 13, 2018 | 10:31 AM
dgi 07's Avatar
what is the full tire size?
Old Dec 13, 2018 | 03:35 PM
Old Dec 13, 2018 | 04:09 PM
dgi 07's Avatar
Then I stand corrected. Check the steering stops but it should really have made no difference...
No spacers?
Old Dec 13, 2018 | 05:49 PM
Are the stops in the hub? I did have a front hub replaced wonder if they didn't set it properly
Old Dec 13, 2018 | 07:35 PM
Best4x4's Avatar
Steering Stops are on the knuckle. 16 & 18inch = a different stop, but honestly it's a 50/50 chance what you have. I've seen them wrong right off the factory floor. I myself personally replace em with a bolt with either washers or a spacer and customize them per the D2.
RawFaith
Mar 25, 2016 12:31 PM
badassbmwm3
Aug 22, 2015 07:23 PM
Draayer
Oct 17, 2012 08:48 PM
TATZOO
Jul 7, 2012 09:41 PM
TexasBadlands
Jun 12, 2006 07:47 PM
