TPS question
Old Apr 7, 2019 | 06:56 PM
yardpro's Avatar
Default TPS question
So after my sons recent maf/CPS Issue, I was scrolling through the obd2 data.
when we removed the intake to check duke pressure we noticed the throttle cable was loose.
the TPS was only showing 82% throttle when floored.
we tightened the cable and now it’s just over 90,
does it indeed go to 100%?
Old Apr 7, 2019 | 08:02 PM
Ben Matheson's Avatar
What does it read if you open it fully by hand at the tb
Old Apr 8, 2019 | 05:03 AM
yardpro's Avatar
Just over 90%
Manually wide open
Old Apr 8, 2019 | 07:13 AM
I wouldn't trust just the scanner. Only way to be accurate is measure voltage at TPS and compare to rave.
Old Apr 8, 2019 | 11:16 AM
Jeff Blake's Avatar
Yes, my code reader reads 100 max WOT. There's a section in the RAVE for the correct cable adjustment. Do that first. If still off, test the voltage on the TPS manually with a multimeter. Failing that, probably a new sensor.. I would with genuine only here, not the cheap one on RockAuto, don't forget a new o-ring,
toofaroffroad
Aug 4, 2018 12:40 PM
stb616
Dec 3, 2014 02:03 PM
Ad!
Feb 7, 2012 12:56 PM
LRD2&ME
Apr 23, 2011 02:19 PM
thehun
Feb 11, 2011 01:48 AM
