trailer wiring harness not getting power???
First off, this forum is phenomenal! A special thanks to disco mike for helping me in the past...
Now onto my issue, albeit minor. I installed a factory trailer wiring harness in 2004 along with the rectangular adapter when I bought my truck and haven't used it since then. At the time it worked well. I've had it on for the last 8 yrs just sitting there. I used it maybe 3 or 4 times , but haven't used it for at least 3 yrs.
I plugged into a boat trailer yesterday, and nothing worked (no brake lights or turn signals.)
Is this a common problem? After I check the connection in the rear brake light, How would I go about troubleshooting it?
Thanks in advance.
Thanks in advance.
how much voltage should I be getting
Thanks Savannah. I determined that it may just have been corrosion, I did a little sanding and cleaning, and I am now getting power, but that didn't fix the problem.
I tested it with a multimeter, and I'm getting about 10.75 volts coming through both the 7 pin and the 4 pin after the converter, but the trailer brake lights and turn signals still aren't coming on.
They did work with another truck a week or so ago, so I don't think it's the trailer.
How much power should be coming through the trailer wiring?
I tested it on a uhaul trailer and it worked with that one. It's still putting out only about 10.75 volts and won't light up the boat trailer, though.
Could it be the 8 yr old harness that's keeping the voltage down, or is there something else that I can check?
gruehle
07-27-2020 09:10 AM
twilightcall
03-06-2012 03:11 PM
