trans clunk/fds play
Old Mar 23, 2010 | 04:24 PM
lipadj46's Avatar
Grease the ujoints and slipshaft every oil change, don't forget the rear driveshaft also.
Old Mar 23, 2010 | 04:57 PM
When you had the front u-joints replaced, did they also replace the centering ball, if not, it is probably about to fail.
There is no normal slop in a t/case, ours are all gears and if it is getting a lot of slop, there may some internal issues starting up.
I little can be normal, I run a 75W/140 gear oil for quieter gears and better wear protection, it helps.
Old Mar 24, 2010 | 07:27 AM
jeremiah's Avatar
i changed the gear oil in transfer case yesterday with 85w-140. i followed the write up. greased all u joints including rear. yes, mike i had the center ball changed also. slipshaft? please explain. i dont know what that is.
Old Mar 24, 2010 | 08:08 AM
oljohnboy's Avatar
the slipshafts are your driveshafts. The driveshafts should have a grease fitting on them. The shaft extends when your wheels are articulated. It needs grease to operate smoothly. I cant see how U Joints would cause play. There is no possible movement a u joint can make to do that unless it is 100 percent broken, which would be undrivable. When you move your shaft around, you need to pay close attention to what is actually moving. Is it moving all the way into the transfer case? or into the differential?
Old Mar 24, 2010 | 08:46 AM
jeremiah's Avatar
johnboy- yes the front driveshaft moves into transfer case and diff. but the sound im hearing seams to come from transfer case. kind of like a click clack when rotating it. ive only had the truck for about a month so i dont really know what could be considered normal.
abran
Apr 27, 2014 06:59 AM
xmarksit
Nov 26, 2013 08:37 AM
EricTyrrell
Feb 8, 2012 02:10 PM
DiscoMike2003
Nov 13, 2008 04:57 PM
The People Family
Aug 6, 2008 10:32 PM
