trans. filter change?
Old Apr 11, 2006 | 09:37 PM
JRdisco1's Avatar
Default trans. filter change?
I have had this kit for a while got it at roverparts.com. Anyone have any insight on replacing this filer? I have never messed with trannys very much, other than checking/changing fluid. It doesn't look like much in the manual, but with what little experience small things always get in the way.
Old Apr 12, 2006 | 12:50 AM
Drnknmnky13's Avatar
Default RE: trans. filter change?
There is a good writeup with pics at Discoweb.org. Go to the tech section then scroll down to transmission disco2. God luck.
Old Apr 12, 2006 | 12:47 PM
JRdisco1's Avatar
Good stuff. Anyone have info on a Disco1? i read there is some extra steps invloved on the discoweb.org...
Old Apr 17, 2006 | 06:07 PM
LordOphidian's Avatar
I haven't done it yet, but for the D1 you need to remove a portion of the exhaust and the frame crossmember before you can drop the pan. Also the drain plug on the D1 takes a 5mm rather than the 8mm on the D2s.
Donnysju
Apr 1, 2014 09:20 PM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
thehun
Nov 17, 2010 06:09 AM
The People Family
Aug 6, 2008 10:32 PM
