trans. filter change?
I have had this kit for a while got it at roverparts.com. Anyone have any insight on replacing this filer? I have never messed with trannys very much, other than checking/changing fluid. It doesn't look like much in the manual, but with what little experience small things always get in the way.
I haven't done it yet, but for the D1 you need to remove a portion of the exhaust and the frame crossmember before you can drop the pan. Also the drain plug on the D1 takes a 5mm rather than the 8mm on the D2s.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
The People Family
Aug 6, 2008 10:32 PM
