Trans fluid leak
Old Sep 24, 2019 | 06:18 AM
Paddywaddy19's Avatar
Default Trans fluid leak
When I start my disco2 I get a rough sound and when I put in gear it hesitated then I could feel it catch then sluggish start then she has a rough time going through gears
Old Sep 24, 2019 | 08:41 PM
Llamasayswhat's Avatar
That sounds horrendous. Do you have an exhaust leak? Is that noise your transmission?
You should fix your leak, and verify your fluid is the correct level with the appropriate tools.
If you don't have them, please contact a qualified mechanic
Old Sep 25, 2019 | 08:31 PM
That is what it sounds like when I start it up and the leak is coming from where the tranny meets the block
Old Sep 26, 2019 | 08:18 AM
TimInNova's Avatar
"the leak is coming from where the tranny meets the block"
I seriously doubt that's transmission fluid. More than likely the rear main crank seal is leaking oil. Check out this video: https://www.roverparts.com/resources...ces-v8-engine/
You need to get it to a shop and have them drop the transmission to inspect/fix it.
Old Sep 29, 2019 | 11:10 PM
Dipstick says oil is full and the liquid is reddish
Old Sep 30, 2019 | 04:44 AM
shanechevelle's Avatar
Front seal on the shaft perhaps.
jpluncford21
Jan 11, 2016 09:16 AM
COBRA
May 27, 2013 02:17 PM
Snafu / Disco Fries
Feb 10, 2011 01:13 AM
Chef3848
Jan 10, 2011 08:02 AM
ROVERTECH15
Mar 27, 2010 10:14 AM
