Trans fluid leak
When I start my disco2 I get a rough sound and when I put in gear it hesitated then I could feel it catch then sluggish start then she has a rough time going through gears
That sounds horrendous. Do you have an exhaust leak? Is that noise your transmission?
You should fix your leak, and verify your fluid is the correct level with the appropriate tools.
If you don't have them, please contact a qualified mechanic
"the leak is coming from where the tranny meets the block"
I seriously doubt that's transmission fluid. More than likely the rear main crank seal is leaking oil. Check out this video: https://www.roverparts.com/resources...ces-v8-engine/
You need to get it to a shop and have them drop the transmission to inspect/fix it.
Snafu / Disco Fries
Feb 10, 2011 01:13 AM
