Trans oil cooler line disconnect
Old May 8, 2016 | 07:55 PM
evoblade's Avatar
Default Trans oil cooler line disconnect
2004 D2
What's the trick to getting the transmission cooler lines disconnected from the cooler? I was pulling back on the disconnect (away from the cooler), and although it moves a bit in that direction, it doesn't disconnect. I'm sure I'll be kicking myself once I get it, but for now I'm stumped.
Old May 8, 2016 | 11:44 PM
chubbs878's Avatar
Originally Posted by evoblade
2004 D2
Push it forward toward the cooler, squeeze the tabs, then slide it back while still squeezing the tabs. It almost takes both hands; one squeezing and the other pulling and wiggling.
Old May 9, 2016 | 07:48 AM
BackInA88's Avatar
Sometimes there is a lot of dirt and junk inside the plastic disconnects making them hard to slide.
I clean them out with some brake cleaner and compressed air than a little WD-40 to lube them up for easier sliding.
Old May 9, 2016 | 08:45 AM
abran's Avatar
Good suggestion! I also use a twisting motion while pulling. They used to be my nemesis, but now I've got their number. Although I will try the cleaning/WD40 technique.
Old May 9, 2016 | 11:33 AM
acg's Avatar
acg
Evo,
Are you looking to disconnect the trans oil cooler lines to change out the radiator? If yes, there is no need to disconnect the former. It is possibly to slide the radiator up and out with the trans oil cooler lines intact. Just thought I mention it to save you some time.
Old May 11, 2016 | 01:42 PM
evoblade's Avatar
Got it!
Thanks for the tips guys.
DustyLBottoms
Mar 5, 2015 01:41 PM
Beaulim
May 2, 2014 08:03 PM
javven
Jul 15, 2012 10:09 AM
armyproud
May 23, 2009 04:10 PM
The People Family
Aug 6, 2008 10:32 PM
