Transfer Box Fill Plug
Old Nov 2, 2015 | 10:55 PM
jfall's Avatar
yeah I have done this.
You will need a 1/2 inch drive - a short stubby extension.
And you will need a swivel.
and patience.
Old Nov 3, 2015 | 06:08 AM
Andrew0's Avatar
Originally Posted by lordmorpheus
X2 on this. I fought with my fill plug the first time I did the service. I got to thinking, "Is there anything else I can use that has a 1/2" square drive?" After a few beers, I remembered the serpentine belt tensioner tool. I rented one from where I work (O'Reillys) and had the plug out within minutes.
Forget WD-40. I've mentioned it before on this board about my new go-to penetrant in a can. https://seafoamsales.com/deep-creep/ I used to use PB Blaster, but this stuff makes the PB look like water.
x2 on deep creep. Or at least use PB Blaster. WD-40 is good for greasing a squeaky door hinge, that's about it.
Old Nov 3, 2015 | 06:40 AM
drowssap's Avatar
deep creep is great but at 9-$10 a can you have to pick your uses
Old Nov 3, 2015 | 10:54 AM
DiscoCam's Avatar
Going to try PB blaster today after work. I'll check O'Reilly for that tensioner tool.
Thanks for the input.
Old Nov 3, 2015 | 01:17 PM
lordmorpheus's Avatar
True. It isn't cheap. After I broke the first bolt on the steering pump bracket while doing head gaskets, I sprayed nearly every bolt after that (at least every bolt that didn't come out with less than 5lb/ft of force). Same thing on my lift kit. If the bolt wouldn't come out very easily, I sprayed them. I would rather spend $10 on another can than having to extract a broken bolt and possibly tap new threads.
losinov
May 8, 2011 02:56 PM
Disconoobie
Oct 19, 2010 07:36 AM
Disco Alan
Apr 21, 2009 06:22 PM
jrkstore43
Mar 2, 2009 08:27 AM
Phototone
Apr 7, 2008 03:59 PM
