Transfer case 00 vs 04
Old Jun 9, 2014 | 08:33 AM
ralphobell's Avatar
Default Transfer case 00 vs 04
What is the difference in the 2000 and 2004 model transfer case? Is there any issue putting in the 04 case in a 00 model? I know the Transmissions were different and a bit longer but do not know if the Tcase is the same or not?
Old Jun 9, 2014 | 12:49 PM
jafir's Avatar
03 and 04 don't have the safety solenoid in the transfer case try had it in the shifter, so you'd no longer have that feature in the 00 if you use an 04 case.
The 04 has two switches for the CDL light on the dash. I have no idea why, and I'm not sure of the harness arrangement, but I'm sure you could make it work just by hooking up one switch. Maybe even both in parallel.
Old Jun 10, 2014 | 06:58 AM
Lowest Bidder's Avatar
I believe that not all the transfer cases from 04 have CDL.
Old Jun 10, 2014 | 08:51 AM
jafir's Avatar
I've never seen one that didn't, but anything is possible.
Old Jun 10, 2014 | 09:22 AM
All 04 t/cases had a CDL
Old Jun 10, 2014 | 10:08 AM
My mistake! Sorry! I thought CDL was optional in 2004.
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
