Transfer Case
Old Sep 4, 2013 | 04:13 PM
Braxton's Avatar
Sorry about that. They came off the same year model as the one I own, 2002.
Old Sep 4, 2013 | 09:30 PM
floundering's Avatar
A 2002 should not have a CDL t-case in it OEM. But perhaps it was a CDL case from a 1999-2001 that replaced the OEM on the donor vehicle, same as you're doing now. Re-read DiscoMike's reply. But in any event, don't think there would be any compatibility issues. The 2002 wiring may still have the mate to the "extra" connectors for the donor t-case. Take a pic and post so we can confirm the extra connectors!!!
Old Sep 5, 2013 | 02:23 PM
Braxton's Avatar
Here is the pic of the connectors on the replacement TC, mechanic says my DII does not have the wiring for these connectors.
Old Sep 5, 2013 | 07:07 PM
CDL sensor. See attached 11 is for warning lamp and 12 is a detent plug. Looks like your donor may have had a CDL linkage installed in it's previous life. That empty bolt hole in the lower left of your pic should have a bolt in it. The bracket for the CDL attaches there using those bolt holes. Dismantler probably remove the shift linkage and left the holes empty.
Old Sep 6, 2013 | 05:04 PM
Braxton's Avatar
Thanks identifying the connectors. I'm still not clear whether this TC will work with on my DII, would hate to have it installed then it not work.
Old Sep 7, 2013 | 08:41 PM
Mel Morales III's Avatar
5th Gear
Originally Posted by Disco Mike
Do you have a 2 cable shifter or one with mechanical arms like from a D1?
The difference in length is not worth worrying about.
Hi mike. Only have one. After getting the new tranny and tcase installed, it wont go into gear - just high revs. It wont engage. What gives? Do i need to reprogram the computer? Please let me know. Thanks!
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
