Transfer case fill/drain plug replacement
Old Nov 25, 2020 | 08:13 AM
zski128's Avatar
Default Transfer case fill/drain plug replacement
I know how to get the fill drain plugs off using a serpentine belt tool but has any one swapped them for a low profile hex head plug instead? This way a regular combination wrench can be used.
Old Nov 25, 2020 | 09:01 AM
Red5's Avatar
Why not just use a 1/2" ratchet?
Old Nov 25, 2020 | 10:09 AM
Richard Gallant's Avatar
@Red5 on my disco you would never get a ratchet in there, there is a cable that is in the way and very tight. A cheap 1/2 drive serpentine tool is perfect, it was all of 10.00.
Old Nov 25, 2020 | 10:13 AM
zski128's Avatar
You can but need wobble extensions or adapters. For the fill plug I used a 1/2 - 3/8 drive adapter with a 4” extension. The drain is more difficult with the crossmember in the way. Both plugs are pretty rough and a little rounded off. If I can replace them with a hex head plugs instead of 1/2 drive plugs just makes servicing easier next time.
Old Nov 25, 2020 | 12:15 PM
Harvlr's Avatar
Sorry for my ignorance but what is a serpentine tool?
Old Nov 25, 2020 | 04:09 PM
acg's Avatar
acg
Old Nov 26, 2020 | 11:35 AM
Harvlr's Avatar
Thanks for the reply.
Old Nov 28, 2020 | 11:05 AM
zski128's Avatar
For future reference the drain/fill plugs are both 26M x 1.75 thread and 16mm long. Drain plug just has a magnet attached on the back.
Old Nov 28, 2020 | 09:50 PM
swissarmychainsaw's Avatar
I just did mine using a combination of 1/2" and 3/8" exentions, it was a bit fiddley but got it done. How often are we changing the fluid on these things? It it was like Engine oil I might make a swap, but for once a year or so I can live with it.
za105
Mar 27, 2018 08:08 PM
smoker
May 22, 2012 09:26 PM
Clearday714
Nov 11, 2011 05:42 PM
Lchop1.8T
Sep 19, 2011 03:00 PM
chad420
Jul 28, 2009 11:32 AM
