Transfer case woes
Old Sep 11, 2014 | 05:58 PM
Paul Grant's Avatar
Originally Posted by DustyLBottoms
In fact some members feel is the better option, since it's quicker that dropping the entire transfer case.
I have a feeling that most members who actually do this kind of swap are using front output assemblies from earlier DII's rather than DI's.
Old Sep 11, 2014 | 06:02 PM
Paul Grant's Avatar
Originally Posted by Richard Moss
I'm not sure of the physical compatibility between a D1 transfer box and D2 propshafts, but a D1 transfer box should have a locking centre differential so you can install the complete D1shift mechanism and gain the bonus feature
Richard, you're spot on with regard to the DI front output assembly and the DII front propshaft. If one chooses to use a DII front propshaft on a DI they would also need the front output flange from a DII transfer case as well. It is larger than the flange on a DI LT230. I just sold someone a DII shaft and flange for this very purpose.
Now, going the other way, while I don't know why someone would, installing a DI front output assembly would necessitate the use of the DII front output flange to enable fitment of the DII propshaft. Mechanically this will work but, again, there is the issue of the hi/lo detect sensor and how it informs the engine ECU and transmission ECU along with the BCU. I can't recall anyone I know going this route so I can't speak from experience.
Old Sep 11, 2014 | 07:17 PM
Paul Grant's Avatar
One last thing. If anyone is need of an early DII transfer case or output assembly, I have them. If anyone is interested in the final incarnation of the LT230, the venerable 2004 LT230SE with the nipple, I have one of those as well. PM me and we can tall about prices.
Old Sep 11, 2014 | 07:25 PM
OffroadFrance's Avatar
Not wishing to hijack the thread, but has anyone lifted down an LT230 on their own below the truck whilst on axle stands. I am considering doing this but it weighs 55kgs. I am considering buying a motorcycle lift, either scissor type or hydraulic and a used angle milling table in place of an LTR-99-010 bracket. I'd be interested to hear of others experiences.
Old Sep 11, 2014 | 07:28 PM
Paul Grant's Avatar
The best thing to do to handle both the weight and awkwardness is to take the transmission brake assembly off. Right there you lose about 45 pounds. Then the transfer case weighs about 100 pounds and it much easier to manage on your own. To remove the brake assembly you have to first take off the screw securing the drum, then the four 15mm bolts holding the backing plate to the transfer case main body. It take five minutes and makes a world of difference.
Old Sep 11, 2014 | 07:32 PM
RicketyTick's Avatar
What about one of the small scissor type transmission jacks on wheels? they go up pretty high. not sure how high you have it on the stands. If you have anything like harbor freight over there, they carry one for pretty cheap $.
Old Sep 11, 2014 | 09:41 PM
abran's Avatar
I use a transmission jack, no adaptor plate.
Old Sep 11, 2014 | 10:00 PM
cburns's Avatar
yeah, i heard it was a long dirty, difficult job. i was hoping to just transplant the front output flange but since there is a chance that the internals are broken, looks like i will be doing an entire transplant. i was hoping someone had a similar experience with their case and it was either remedied by the front output transplant or something as simple as an internal linkage...based on the fact that it is stuck in low, i am beggining to think that it is a shift fork or selector. looks like i will have a couple long weekends ahead of me!
Old Sep 12, 2014 | 05:44 PM
Thank to all you guys. I'll remove the parking brake assy first and use a scissor lift and then lower it down ........... carefully. If I don't post on here again you'll know I dropped the ba___rd on my head and I'm with the fairies . ................ not that it could do any brain damage in any event
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
