Transmission Cooler Lines - where to buy?
Old Aug 13, 2022 | 11:53 AM
  #21
RA122125's Avatar
Banned
Originally Posted by Harvlr
If you do use stainless, make sure you use some anti-seize on the threads. I doubt that the issue was over torquing. I’m an aircraft mechanic and we frequently use stainless AN (or more commonly MS) fittings. Unlubed stainless will gall up and seize.
I agree with that, Stainless will typically gall and seize, especially when in contact with Aluminum. That's why I was wondering if anybody had a connection for the brass ones, or even a price so I might know what to expect. Seems like a great idea, if you can find the product somewhere...ahh, the joy of supply chain issues, lol
Old Aug 14, 2022 | 12:21 AM
  #22
Discorama's Avatar
14mm compression fittings fit on the radiator (some sanding required, because the tubing is about 14.2mm OD). Check out McMaster-Carr. All other parts (hoses, adapters) you get from summitracing. Should be possible to build the lines for under $200.
Jeff Blake
Jan 28, 2017 10:32 PM
archaeology_student
Aug 22, 2016 11:17 AM
Rover Nick
May 1, 2014 08:40 PM
DarylJ
Apr 14, 2011 09:11 PM
