transmission filter replacement with pics
Old Apr 11, 2011 | 07:25 AM
sloan74's Avatar
the Advanced Auto/Autozone is the same one as the AB pretty much.
and do not use RTV.
Old Apr 11, 2011 | 07:36 AM
Snafu / Disco Fries's Avatar
Thanks for the write up! I did the fluid, but didn't do the filter yet. I figured I would do that the 2nd go around since you only get 1/3 or 1/2 of the actual fluid out each time. The job would be 10X easier if there was fill tube on these things. I used the hand pump, but might look at making a set up like you did.
Old Apr 11, 2011 | 01:06 PM
iownme's Avatar
with only 2 small hand bends in the pipe, it was self supporting, when i needed to see when fluid was coming out of the fill hole it could be seen easily, and just pull the tube forward 1" and you can replace the fill plug, go thru the gears, get back under, remove the fill plug, and the tube is right there ready to re-insert into the fill hole. For me, i think easier than the pump
thehun
Mar 7, 2013 01:35 AM
cationmoted
Jan 8, 2012 11:40 AM
LRScott
Mar 9, 2009 01:04 AM
KeizerRover
May 17, 2008 08:18 PM
texmanmoore
Feb 23, 2008 02:39 PM
