Transmission fluid
Old Aug 11, 2018 | 12:11 PM
Ronaldusmax's Avatar
4th Gear
Default Transmission fluid
Cannl someone help me locate where I can check transmission fluid on a 2003 landrover discovery?
Old Aug 11, 2018 | 02:48 PM
Richard Gallant's Avatar
Underneath , but basically just behind the oil pan and above 8mm hex (Allen Key)
You check cold and just a dribble should come out when you remove the bolt,it can be areal bitch to get the bolt out
Get a copy of the RAVE manual it will help a lot.
Old Aug 11, 2018 | 03:44 PM
ahab's Avatar
There is no way to "check" the fluid level in the conventional sense of what those of us who grew up with dipsticks are used to. Land Rover engineers decided those were too bourgeois and they went for a more convoluted approach. First, you start the truck and cycle through all the gears, pausing for a couple seconds in each. Then return it to park, set the handbrake and get under the truck (with it still running) and remove the fill plug. ATF should dribble out at about a drip per second. If this doesn't happen, fill until it does. Not only is the Rave an excellent resource for this type of thing, Atlantic British has some good DIY videos as well. If you're hankering for the good old days, get a pan and stick from a D1 and it will bolt right on so you can once again enjoy times when life was simpler.
Old Aug 11, 2018 | 03:48 PM
The Deputy's Avatar
https://www.justanswer.com/car/2d3p8...covery-ii.html
Within this webpage, there are directions for draining and refilling transmission. My only suggestion would be, deviate from the directions...where it says drain fluid by removing drain plug and then remove fill plug. I would suggest removing or at least loosening the fill plug first. No sense draining it...and then find out you can't the fill plug out to refill.
Brian.
QuakerJ
Apr 21, 2014 07:41 AM
hriant88
Aug 6, 2013 05:09 PM
FLDiscoII
Jun 19, 2012 10:47 AM
DaveLRDII
Aug 29, 2011 03:48 AM
Jupe209
Aug 29, 2010 11:29 AM
