Transmission help
Old Sep 26, 2010 | 08:10 PM
rbaaddison's Avatar
7th Gear
Default Transmission help
i have a 2002 land rover and i am changing oil in the zf4hp22 transmission and i cant find the oil check level and i was wondering if i could get any advise from here.
Thank,robert
Old Sep 26, 2010 | 08:29 PM
lipadj46's Avatar
Read the sticky on how to change the transmission fluid in a DII. I will give you a sneak preview, there is no transmission dipstick.
Old Sep 27, 2010 | 07:59 AM
If you have changed the fluid and didn't use more then 5 quarts of fluid, do not drive it, cause you'll be low on fluid and cause problems.
*** already mentioned, read the sticky.
Speed racer
Oct 11, 2008 10:56 PM
MCA
Oct 4, 2006 01:45 PM
dirkmc3
Oct 7, 2005 09:26 PM
imag
Oct 4, 2005 12:17 AM
