Transmission Line
Old Jul 4, 2021 | 07:49 AM
merebel's Avatar
Default Transmission Line
OK so the quick connect at the cooler side keeps leaking on me. o-rings replaced a few times cleaned etc. Quick connect is easy to remove and re attach so not gummed up. So question is this as i do think these are low pressure lines, can the rubber hose part be removed and replaced?
Just clamping it on each end with a couple hose clamps?
Old Jul 6, 2021 | 10:19 AM
whowa004's Avatar
Amazon Amazon
Amazon Amazon
can use this combo to fix the oil lines as well. Super easy and well worth the money.
Old Jul 6, 2021 | 10:32 AM
dswilly's Avatar
If you can get ahold of PT Shram he has a kit for this. Great guy. My line blew off and I got the PT kit. So far it has worked great. Uses a proprietary quick connect for the cooler end then a compression fitting for the hard line end with high pressure hose inbetween. You find a place to splice into the hard line. FYI - A PEX disconnect tool works great to remove the stock quick connect fittings. I used a plumbing pipe cutter to cut the hard lines.
P. T. Schram Rover Repair Land Rover Parts Service
Old Jul 6, 2021 | 11:08 AM
merebel's Avatar
Originally Posted by whowa004
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Have you done this ?
Old Jul 6, 2021 | 12:01 PM
whowa004's Avatar
yes. Both sides of the trans line at the cooler and one side of the oil line at the cooler (so 3 of the 4 push connectors replaced with this) with zero leaks.
Old Jul 6, 2021 | 12:13 PM
dswilly's Avatar
Regardless of which setup you go with be aware that the transmission pipes are 14mm +. So a bit of sanding is usually required to get fittings to slide on. Be gentle as they are thin and soft and can be distorted out of round if not careful.
Old Jul 6, 2021 | 01:08 PM
whowa004's Avatar
correct, some sanding was required, I used a strip of 400 grit and just went nice and slow. The pipes are aluminum so it doesn't take much pressure or time to get them to work.
shanechevelle
Mar 9, 2017 08:22 AM
Jeff Blake
Jan 28, 2017 10:32 PM
CoMo
Aug 19, 2015 04:23 PM
hh65flyer
May 13, 2013 06:59 AM
cationmoted
Jan 8, 2012 11:40 AM
