transmission problem
i have a series 1 and currentyly i am redoing the engine because of a over heat issue and very low compression due of. . the second issue is that before the engine died my transmision would seem to slip a lttle in drive then catch fine but if you dropped it into 1 there would be no slippage or any problems.. any ideas
ORIGINAL: cterrebonne
150,000 last service was at 117,000 and the level should be correct but i dont think it smeels burt...when you say rebuilding what that invlolves?
Before I would do that I would change the fluid, not the filter and add a bottle of Lucas tranny additive, drive it for a week, if nothing changes then it is safe to say your tranny is dying.
A rebuilt or exchange tranny is one that has had all it's internal wear parts replaced like seals clutch plates valves and or soloinoids replaced along with a rebuilt torque convertor.
Mike
JMG03
May 5, 2007 11:55 AM
