Transmission Problem - Won't Go Into Reverse
Old Nov 11, 2019 | 10:29 PM
Papag1313's Avatar
Default Transmission Problem - Won't Go Into Reverse
You guys have saved my bacon before so here goes with another question:
On Cold Start (Parked for 3 hours or more), put my 01 Disco in Reverse. No problem
Drive 10 to 15 minutes then park it for about an hour. On restart, if you put it in reverse it acts like it's in Neutral. No Reverse....
Move the Gear Selector to drive then back to Reverse, still nothing......
Then amazingly after 3 to 4 minutes, it either warms up or pressure builds up and it works till I stop again......
Linkage seems fine.
Any suggestions on what I should look at or be looking for?
Thanks!
Papa G
Old Nov 12, 2019 | 12:35 AM
Richard Gallant's Avatar
I would do a transmission service, if you are DIY guy you can either just do the fluid, or drop pan the and do the filter. I would suggest dropping the pan.
Read up on the process it is actually very easy but the Disco has to be running to get the transmission full. And if you do it yourself filler plug always comes out 1st - also while the Disco is running.
With luck that will clear up the problem, it could just be something sticking from low or dirty fluid.
Otherwise it is likely a bigger deal.
Any codes stored ?
Old Nov 12, 2019 | 07:27 AM
Sandman614's Avatar
I would check fluid level first. If it's low that might explain the situation. Fill it to the proper level and then see if anything changes.
kenneypj1
Nov 30, 2018 04:46 PM
nack
Nov 3, 2013 08:39 AM
jmason
Sep 28, 2013 03:26 PM
suzukisam967m
Oct 1, 2012 04:50 PM
MuleyJ
Aug 19, 2012 08:02 PM
