Transmission Question
Old Jul 13, 2011 | 07:07 PM
kmyer01's Avatar
Default Transmission Question
I am having my first big problem with my 2001 disco II....i've been lucky I guess. Anyway, my rover would not go into reverse the other day, so i parked it (on a hill). Went to cuss it out in the garage, came back and it went right into gear. so I checked the trans fluid, thinking it might be low...my burnt arm says otherwise. I was told by a local mechanic that it may not be the trans but actually a switch of some kind. I was just wondering if anyone had an idea of what's going on? the gear lights have been going off and on lately to.
thanks
Old Jul 13, 2011 | 07:19 PM
DarylJ's Avatar
He is talking about the XYZ switch.
And having the lights on the shifter turn on and off sounds a whole lot like that might be the problem.
But I'm not much of an auto transmission guy, so I'm sure others will chime in.
Old Jul 13, 2011 | 08:22 PM
Rovin4life's Avatar
iF it wont go into reverse then its probably something slipping. Does the rpm counter go high when it won't go into reverse.
Old Jul 14, 2011 | 07:49 AM
How often do you service the tranny, have you checked the fluid, is it low and or burned?????????????
Old Jul 14, 2011 | 07:50 AM
kmyer01's Avatar
the rpms dont spike when I put it in reverse...well unless i press the gas. The car is sitting right now, but have been out a few times to start it again put it in gear and it is just fine. So i am lean more towards the XYZ switch at this point, but i need more input.
Old Jul 14, 2011 | 07:54 AM
kmyer01's Avatar
I just got the disco about a month ago, and I check the trans fluid before i bought it...it seemed good. I just changed filter and fluid a week ago.
Old Jul 14, 2011 | 09:48 AM
It is not the XYZ switch.
Send me your number so we can talk, I think you are going off in the wrong direction. By the way, is your service engine light on?
hubris
Dec 14, 2007 09:31 PM
open range
Mar 21, 2007 02:00 AM
Benhamtroll
Feb 9, 2007 11:17 PM
stripperluvva s wife
Mar 24, 2006 11:49 AM
JKK
Oct 13, 2005 10:49 PM
