Transmission stuck in park
Old May 10, 2017 | 01:41 PM
handsome rob's Avatar
Default Transmission stuck in park
I need some help. My 2001 D2 with 149K on it is stuck. I was launching my boat when I put it in park and then the weight pulled me back a little and the transmission park caught the weight. Now it wont come out of park and I have the 4 wheel dash ligh with the X in the middle. The manual says it is the TC lock but I cannot find how to disengage so I can move. I have pulled it up t the top of the launch but I cam stuck here now and hoping to get it moving. Any ideas?
Old May 10, 2017 | 01:55 PM
I also do not have any brake lights so I am thinking the brake switch?
Old May 10, 2017 | 02:05 PM
mln01's Avatar
Sir, I do believe you diagnosed the problem. The brake light switch is #1 on the list when almost any vehicle won't come out of park, and no brake lights reinforces the diagnosis.
There is a newer version of the brake light switch that's been out a few years. AutoZone sells it in their Duralast box but it has the Land Rover logo molded into it so it's OEM. It's priced at $15.99 at the AutoZone web site.
Best Stoplight Switch Parts for Cars, Trucks & SUVs
In the meantime you can pull the shifter surround and release the shifter manually.
Old May 10, 2017 | 02:13 PM
I was able to move the park switch pin and drive it out of the way, but I will get the new switch and hopefully be back working again.thaks for the help
Old May 10, 2017 | 02:23 PM
OverRover's Avatar
It does sound like a brake light switch. But for giggles check the brake lights when you have the trailer wiring unplugged. I had this happen once, and the trailer light module was bad and not the brake light switch. Check the fuse on the trailer wiring kit/module too. Good Luck!
Old May 10, 2017 | 02:39 PM
I actually installed a new 7 blade wiring connector yesterday and I am thinking that is what maybe caused the issue with the brake light switch. I have one coming from Advanced Auto this afternoon so hopefully I have the Disco back fully functioning again. Thanks for all the help.
Old May 12, 2017 | 09:42 AM
Okay new switch did not fix my issue. I still do not have any brake lights and it wont come out of park. When the vehicle is running and I push on the brake pedal I get a 4 wheel and drive line picture that has a red X through it. the manual says differential lock warning lamp. I am not sure what this means as if I push the pin over on the shift lever it will allow me to drive just fine and when in neutral I can change from high to low, so maybe another sensor somewhere giving me trouble?
I appreciate the further help on this one.
Old May 12, 2017 | 10:10 AM
Never mind, I am apparently not very intelligent and was checking the wrong fuse. I found the right one and it works fine now. Thank you for all the help as this forum is awesome.
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
ogden45
Apr 15, 2007 03:51 PM
