Tricky Dick - Front Hub
Received 1,189 Likes
on
That's your lower ball-joint. The fluid looks like it's coming from axle, probably bad seal or vent is plugged. There's a plastic vent line coming out of the drivers side of front axle housing, push down on outer ring and pull plastic tube out/upward. Once removed, blow out tube with compressed air. Do the same to the rear axle and transmission vent.
Brian.
Brian.
