Tricky Dick - Head Gasket Replacement
Old Jan 16, 2020 | 01:21 PM
  #131
Dave03S's Avatar
P38's were not all 4.6 actually... Many were made with 4.0 engines...
Old Jan 16, 2020 | 01:48 PM
  #132
Richard Gallant's Avatar
@Sixpack577 those lists are missing some later 04 numbers mine starts with 08D
Old Jan 16, 2020 | 01:49 PM
  #133
Sixpack577's Avatar
Yeah, there is more to it, but that is all that I had saved.
Old Jan 16, 2020 | 01:51 PM
  #134
Sixpack577's Avatar
I did not know that.
Thank you, and sorry for bad info.
Old Jan 16, 2020 | 02:10 PM
  #135
RoverSE7's Avatar
Thanks Guys you are the best!
Old Jan 16, 2020 | 04:12 PM
  #136
Best4x4's Avatar
Yep early SE model P38’s were 4.0L & HSE were always 4.6L. Near the end of the P38 the SE model vanished and all were HSE 4.6L.
Old Jan 18, 2020 | 06:42 PM
  #137
Friday Night Disco's Avatar
UPDATE
Checked the gap on the throttle cables and I was right at .2
After I adjusted the cable mount, I have not see any issues with the IAC or P0505 codes
After replacing the MAF (thanks again Best4x4) I have not seen any P0101 codes
Still getting incorrect gear ratio and lean on both banks, however, I found that one of the hoses on IAC was loose enough, with clamp on, that I could pull it off the upper plenum. Used a worm clamp to get it tightened up. Let's see if that finally gets me back to zero codes.
Side note - I decided that I should put a winch on the truck since Harbor Freight had a liquidation sale ($289).
Old Jan 25, 2020 | 04:27 PM
  #138
UPDATE
I have not gotten any codes after tightening the hose on IAC and doing an adaptive reset. This maybe have been the final issue, I only have 40 miles since adaptive reset (highway and in town).
Old Jan 25, 2020 | 10:10 PM
  #139
Best4x4's Avatar
Great news!!
Old Jan 25, 2020 | 10:24 PM
  #140
Originally Posted by Best4x4
Great news!!
getting close!!! A few pesky coolant leaks and I will be ready for a road trip
