Tricky Dick - Head Gasket Replacement
Old Dec 12, 2019 | 07:39 AM
  #31
Sixpack577's Avatar
Originally Posted by mln01
Others have reported good results with a bolt like the one linked below.
Irwin Tools BOLT-GRIP Extractor Expansion Set, 5 Piece, 394002 https://www.amazon.com/dp/B000QW6K8I..._42I8DbHCFSK20
I had to use that on 2 head bolts to get them out.
My impact wouldn't do it, but that socket and breaker bar did.
Next step would've been a drill and an easy out.
Old Dec 12, 2019 | 08:22 AM
  #32
Friday Night Disco's Avatar
I will look into it
Old Dec 13, 2019 | 07:45 PM
  #33
UPDATE
Drilled out the remaining head bolt
Remaining Issues
Broken nipple on radiator <-may dill out and put brass nipple
Broken SAI pipe <-have on local
Broken Bolts for Intake Plenum <-Assuming I can pick up at hardware store
Replace broken breather things on valve cover
Check surfaces for warping
Have someone eyeball pistons and sleeves to see if I am missing any issues
Prep and clean surfaces for gaskets
Check injectors and replace o rings
Old Dec 13, 2019 | 10:08 PM
  #34
Sixpack577's Avatar
You can get a remanufactured(cleaned, tested, new o-rings)set of Bosch injectors on ebay for $60
Old Dec 13, 2019 | 10:43 PM
  #35
thanks, I will look into it
Old Dec 14, 2019 | 04:26 PM
  #36
UPDATE
8 hours into the assembly and calling it a night, I have one exhaust bolt that does not want to go in and I do not want to strip it out or break it off in the head
Replaced O rings on both sides of the injectors
Cleaned heads
Bolted in heads
Bolted in rockers
PENDING
Replace broken bolts for intake plenum
Replace broken bolt for AC and Power Steering bracket
Fined correct PCV valve (bought wrong one)
Pick up SAI pipe
Fix broken nipple on radiator
Old Dec 16, 2019 | 08:40 PM
  #37
UPDATE
about 18 hours into project and 75% done
Ran into an issue getting the intake manifold back on, I do not have the special wrench to torque it down. I will run to Harbor Freight tomorrow
Got the PCV 308 installed on the valve cover
Got a used SAI pipe
Bought bolts and washers to replace the flange bolts that snapped
Bought metric O ring set
Took a picture of left over parts from Lucky8
PENDING
Drill out nipple on radiator and replace with brass 1/4 nipple
Torque the intake manifold
Install valve cover gaskets
Install coil packs
Install upper plenum
Install SAI
Install brackets for AC and Power Steering
Install alternator
Install Cooling
Old Dec 16, 2019 | 08:59 PM
  #38
Best4x4's Avatar
That is an interesting way to mount the FV308, but I don't think it's going to work due to the flow being backwards. The FV308 is supposed to replace the plastic nipple on the Upper Plenum. Then at the Valve Cover you just remove the plastic baffle and on 03-04 D2's drill out the hole to allow for more flow.
I just wanted to point that out before you put it all back together.
Old Dec 16, 2019 | 09:02 PM
  #39
crap... I thought I did it right. I have the brass fitting on the upper plenum already.
Old Dec 16, 2019 | 09:11 PM
  #40
Best4x4's Avatar
Yeah the FV308 is supposed to go on the Plenum to replace the OEM plastic unit or the aftermarket metal one. You get a metal nipple plus a PCV.
If you ran your setup the engine vacuum would completely close the PCV vs it venting.
