Tricky Dick - Head Gasket Replacement
Old Jan 2, 2020 | 09:27 PM
  #81
mln01's Avatar
Regarding the brake servo vacuum line connection at the upper intake, ten years ago I fabbed a solution after breaking the red collar after I first broke the vac line and then the red collar while lying face-down on top of the engine changing the ignition wires.
I happened to have a bag of Radio Shack vinyl grommets lying around. I found one into which the line fit snugly, then sliced it with a razor blade as closely as possible to one side of its center channel. It fit neatly into the upper intake fitting and sealed it effectively. I'm confident it would have worked well indefinitely, but a couple years later I found a good red collar on a boneyard truck and restored the setup to stock.
Old Jan 2, 2020 | 11:08 PM
  #82
Best4x4's Avatar
Glad to help
Old Jan 3, 2020 | 01:53 PM
  #83
Friday Night Disco's Avatar
UPDATE
Drove 22 miles and truck ran like a champ
After sitting for 4 hours started the truck up and idle was rough and got P0101 & P0505, cleared the codes
Drove 18 miles and turned the engine off and got P0101 & misfire on multi cylinders & misfire on cylinder 3
I am going to start by replacing the MAF with a different one and see if the issue continues (Best4x4 can you PM me about price)
Next Steps
If MAF does not solve the issue, I will put old MAF back and replace IAC
Old Jan 3, 2020 | 01:55 PM
  #84
Sixpack577's Avatar
I hate reading this.
I know the frustration of the time put in, only to have problems.
Hoping one of those 2 parts fixes it for you.
Old Jan 3, 2020 | 02:04 PM
  #85
It was fun doing the HGs but, these little things are a bit frustrating, especially when the solution is not obvious.
I feel like I have overlooked something but, let's throw some money at it and see what happens.
Old Jan 3, 2020 | 08:06 PM
  #86
Going through everything again I thought it was funny that I keep saying PCV308 and Best4x4 says FV308
Well...I bought a PCV308
https://www.oreillyauto.com/search?q=pcv308
Did I buy the wrong one??
Old Jan 3, 2020 | 10:44 PM
  #87
Best4x4's Avatar
It’s a Fram p/n lol.
Old Jan 3, 2020 | 10:47 PM
  #88
Is that a yes I got the wrong one?
Old Jan 3, 2020 | 10:51 PM
  #89
Dave03S's Avatar
Looks the same, if it fits, then all you have left is to blow through it to make sure it flows in the correct direction.
Old Jan 3, 2020 | 10:59 PM
  #90
I blew a full cigar through it doing a smoke test, almost passed out...if it is the wrong size, that could be why the MAF is saying WTF and the IAC is freaking out like a squirrel on crack
