Trouble removing 02 sensor
Trying to remove the right side downstream oxygen sensor from wiring harness, but it won't give.
Can feel clip but wonder if there is a bolt that holds clip in place?
Am doing this by "feel", really can't see. Unable to get two hands on wire to undo the plug.
Any ideas?--------------Its a 2004 Discovery 2
Look at your new one for a visual reference. No bolt just a clip try to pull and wiggle sometimes they do get sorta seized up a little, should not be a total nightmare job though. What o2 are you using? Are you replacing all or one or what?
pietch
Dec 2, 2008 10:44 PM
