turn signal
Old Mar 18, 2016 | 12:58 PM
zuke's Avatar
Default turn signal
my turn signal on one side blinks alot faster than the other. all bulbs are good. anybody know a fix
Old Mar 18, 2016 | 05:37 PM
disc oh no's Avatar
Usually when one side blinks faster, it's because one of the bulbs is not pulling enough current. Most of the time, it turns out to be a bad ground. Take a look at how bright they're coming on. If one is dimmer, take a good look at the wiring.
I did have a truck come into the shop a while ago where someone put LED bulbs in place of the originals and they used so little current, both left and right flashed fast like there was a bulb out.
Good luck!
Old Mar 18, 2016 | 06:07 PM
cappedup's Avatar
Yes, if they all check good, bad grounds is next. Often the rears where the cluster unit tends to hold water.
Old Mar 18, 2016 | 07:04 PM
JRAM's Avatar
I had the same problem recently with a turn signal bulb on the tail lamp. Changed bulbs, it worked for a bit then realized the contacts in the bulb socket needed to be cleaned. Try to get the contacts in the socket nice and shiny and then use some dieletric grease to prevent corrosion.
Rover82
Apr 20, 2007 07:01 PM
billinohio
Mar 14, 2007 11:43 AM
95Discovery
Jun 20, 2006 02:56 PM
LordOphidian
May 30, 2006 03:00 PM
95Discovery
Jan 10, 2006 09:41 PM
