Twitchy Steering
Old Dec 18, 2025 | 07:46 PM
  #21
Extinct's Avatar
The centralizing bolt is not really necessary. If your rod ends are tight, have you adjusted the slack screw in the top of the box?
Old Dec 18, 2025 | 09:40 PM
  #22
WeatheredSoul's Avatar
no, this was the adjustment I was going to make. Can I just make that adjustment without the centralizing bolt then?
Old Dec 19, 2025 | 05:44 AM
  #23
Extinct's Avatar
Yes, if you have not done the adjustment screw yet, that is likely your entire problem.
Old Dec 23, 2025 | 04:28 PM
  #24
Externet's Avatar
Removing the steering damper/shock absorber can discard that as a cause.
Old Dec 23, 2025 | 07:18 PM
  #25
I see. I think it’s safe to assume it’s not that since they are both a couple months old and after replacing nothing changed.
I did think about it today and I replaced the steering box about a year ago and the steering still felt the same. It’s worth noting it was a pick and pull box but still seems odd nothing changed which makes me think it’s got to do with the steering column, u joints or something. There has always been a pretty absurd amount of play in the wheel.
Old Jan 6, 2026 | 05:43 PM
  #26
Update: Adjusted the steering box screw and its definitely better now. I think it was fully backed out so I tightened it about 3 rotations.
me 2
Nov 3, 2021 10:55 AM
Ursula
Jul 3, 2015 10:35 AM
Externet
Dec 2, 2014 12:08 PM
Vinndego
Jan 6, 2014 11:14 AM
s10lowrider1994
Jan 7, 2013 09:41 PM
