Which U Joint needs to be replaced
2001 disco, 62,000 miles
Which U joint?
Front, double cardon greasable with centering ball kit.
Is this the only one that should be replaced?
Is one U joint recommended over another? I will be having it done in the shop, but would like to know what they are installing.
Thanks again.
Which U joint?
Thanks again.
I am currently replacing all 3 u joints in the front prop as well as the center ball with Neapco 1-0005 u joints and the Neapco 7-0081NG center ball kit, all from Autozone. While I am under the truck I figured that I would change the roto flex coupler in the rear as well. I should be done tomorrow and I will post the cost and time involved.
