Which U Joint needs to be replaced
Old Feb 16, 2009 | 03:06 AM
sharp's Avatar
Default Which U Joint needs to be replaced
2001 disco, 62,000 miles
Which U joint?
Front, double cardon greasable with centering ball kit.
Is this the only one that should be replaced?
Is one U joint recommended over another? I will be having it done in the shop, but would like to know what they are installing.
Thanks again.
Old Feb 16, 2009 | 07:02 AM
Yes a shop will know what they are doing, and make sure that they also replace the centering ball kit too.
And yes, the double cardon is the one, might want them to do the front u-joint on the front drive shaf also.
Old Feb 16, 2009 | 08:32 PM
nynole's Avatar
I am currently replacing all 3 u joints in the front prop as well as the center ball with Neapco 1-0005 u joints and the Neapco 7-0081NG center ball kit, all from Autozone. While I am under the truck I figured that I would change the roto flex coupler in the rear as well. I should be done tomorrow and I will post the cost and time involved.
doogaloo
Sep 5, 2015 12:29 AM
dtunni
Aug 15, 2013 02:33 PM
nea791
Sep 19, 2009 04:45 PM
AK Rover
Mar 20, 2009 09:51 PM
duckprefect
Freelander
Mar 9, 2009 08:27 AM
