Ultra Gauge and transmission temps
Old Oct 26, 2015 | 02:34 PM
GR from Plaice Cove's Avatar
Default Ultra Gauge and transmission temps
Hi everyone :-)
Is anybody reading transmission temps with their Ultra Gauge? I've read their website, and from what I can make of it, you need to program the UG for it...if it's supported by the manufacturer you're interested in. Am I understanding that correctly? If that's how it works, does anybody have the codes?? I've also tried searching here without any luck.
'04 Discovery
THANKS!
-George
Old Nov 14, 2015 | 11:33 AM
mln01's Avatar
See this post.
Old Nov 20, 2015 | 11:45 AM
Racer X's Avatar
There's a transmission overheat light on the dash that wired to a thermostatic switch on the transmission cooler line, and on the transfer case.
That said, most modern automatic transmissions have a temperature sensor that feeds fluid temp info back to the ECU to determine TC lockup, shift strategies, etc. I don't know that the OBD II protocol by itself is enough to retrieve those metrics.
Old Nov 20, 2015 | 12:49 PM
Thanks Racer X. That's good info to know. It would be nice if I could just get the temps through the Ultra Gauge...but it's looking more and more like I'll have to get a dedicated gauge for it. I don't pull a trailer that often, but when I do, I'd like to know if the trans. is getting too hot.
Thanks for the reply :-)
Rover_Hokie
Feb 2, 2014 03:52 PM
Janadi
Jan 19, 2014 06:03 PM
Spike555
Jan 28, 2013 11:40 AM
AdrenalinPlease
Jan 13, 2013 10:04 PM
hhalimi
Mar 7, 2012 10:39 PM
