Valley Pan Install-'03 Disco
OK gents,
I posted a post before but no straight answered.....so let's try again.
When installing valley pan gasket on '03 Discovery:
1. Do I need to put RTV sealant on the coolant ports on the gasket (2 on each head)? If I do...please explain the best procedure.
2. Do I need to put RTV sealant on the bolt washers (someone mentioned that if you don't, you can get coolant leak from the bolts, which I find hard to believe)?
3. Any other things I should do that RAVE does not call for?
I don't feel doing the same job twice
Thanks!
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Thanks!
I just finished mounting it on. Also I put "blue" locktite on the bolts and a thin coat of black RTV on the bolt washers. I heard that antifreeze has a tendency to leak through the bolts. I figured, since I am already here.....why not
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Cheers.
