Valley Pan Install-'03 Disco
Old Oct 8, 2011 | 10:31 PM
boris_gti's Avatar
Default Valley Pan Install-'03 Disco
OK gents,
I posted a post before but no straight answered.....so let's try again.
When installing valley pan gasket on '03 Discovery:
1. Do I need to put RTV sealant on the coolant ports on the gasket (2 on each head)? If I do...please explain the best procedure.
2. Do I need to put RTV sealant on the bolt washers (someone mentioned that if you don't, you can get coolant leak from the bolts, which I find hard to believe)?
3. Any other things I should do that RAVE does not call for?
I don't feel doing the same job twice .
Thanks!
Old Oct 9, 2011 | 12:29 PM
boris_gti's Avatar
Anyone???
Old Oct 9, 2011 | 02:40 PM
Rovin4life's Avatar
rtv sealant on the parts where the heads meet the block that little space the seals don't cover. then make sure to tighten the bolts in the correct order and torque.
Old Oct 9, 2011 | 03:08 PM
boris_gti's Avatar
Thanks!
I just finished mounting it on. Also I put "blue" locktite on the bolts and a thin coat of black RTV on the bolt washers. I heard that antifreeze has a tendency to leak through the bolts. I figured, since I am already here.....why not .
Cheers.
Beamer1
Dec 11, 2012 07:37 AM
kae
Feb 23, 2010 08:37 AM
JHDisco2
Dec 15, 2009 10:58 AM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
