Valve cover gasket
Old 12-17-2020, 12:13 PM
escott16's Avatar
Should I drill the hole it says in the instructions or is it fine without it
Old 12-17-2020, 12:14 PM
escott16's Avatar
I found this on the instructions “If you have an 03-04 D2 you will want to open up the hole in the tube once you have it out to remove the baffle. You can drill it out to 3/8 or larger or carefully just chop the top off. Then you'll have the best flow to the FV308.***”
Old 12-17-2020, 12:15 PM
mollusc's Avatar
I don't know what size the original hole is in the tube, but some years have a completely straight tube so there's no harm in enlarging it. Be careful not to get shavings into the rocker cavity though.
Old 12-17-2020, 12:18 PM
escott16's Avatar
Alright I’ll remove the baffle and drill the hole out
Old 12-17-2020, 08:41 PM
Extinct's Avatar
Received 1,509 Likes on 1,069 Posts
I use a tubing cutter and cut the top of the tube off with the restrictor
JUKE179r (12-18-2020)
Old 12-17-2020, 09:25 PM
escott16's Avatar
I have that exact tool . Does it matter what length I cut at?
Old 12-18-2020, 05:07 AM
JUKE179r's Avatar
You want enough length for the hose and clamp to be reinstalled.
mollusc (12-18-2020)
Old 12-18-2020, 07:17 AM
Extinct's Avatar
If you look at the tube you can see mating point between the tube and the restrictor disc, the disc is inserted about 3/16" below that so cut that distance between the mating line.
Fast951
09-28-2018 09:45 PM
JumPeR04
08-07-2013 04:35 AM
BFox15
09-07-2011 08:22 PM
maing74
08-26-2011 10:23 PM
thospb
12-01-2010 06:06 PM
Quick Reply: Valve cover gasket
