Valve cover gasket
Old Dec 17, 2020 | 12:13 PM
escott16's Avatar
Should I drill the hole it says in the instructions or is it fine without it
Old Dec 17, 2020 | 12:14 PM
escott16's Avatar
I found this on the instructions “If you have an 03-04 D2 you will want to open up the hole in the tube once you have it out to remove the baffle. You can drill it out to 3/8 or larger or carefully just chop the top off. Then you'll have the best flow to the FV308.***”
Old Dec 17, 2020 | 12:15 PM
mollusc's Avatar
I don't know what size the original hole is in the tube, but some years have a completely straight tube so there's no harm in enlarging it. Be careful not to get shavings into the rocker cavity though.
Old Dec 17, 2020 | 12:18 PM
escott16's Avatar
Alright I’ll remove the baffle and drill the hole out
Old Dec 17, 2020 | 08:41 PM
Extinct's Avatar
I use a tubing cutter and cut the top of the tube off with the restrictor
Old Dec 17, 2020 | 09:25 PM
escott16's Avatar
I have that exact tool . Does it matter what length I cut at?
Old Dec 18, 2020 | 05:07 AM
JUKE179r's Avatar
You want enough length for the hose and clamp to be reinstalled.
Old Dec 18, 2020 | 07:17 AM
Extinct's Avatar
If you look at the tube you can see mating point between the tube and the restrictor disc, the disc is inserted about 3/16" below that so cut that distance between the mating line.
Fast951
Sep 28, 2018 09:45 PM
JumPeR04
Aug 7, 2013 04:35 AM
BFox15
Sep 7, 2011 08:22 PM
maing74
Aug 26, 2011 10:23 PM
thospb
Dec 1, 2010 06:06 PM
