valve cover seapage
Old Mar 1, 2008 | 03:36 PM
jdelp's Avatar
Default valve cover seapage
Not bad enough to replace yet, but I want to give them a 1/4 - 1/2 turn to see if the slow leakage stops...at least for now. What size socket do the vc bolts take? I tried several english and metric sizes but nothing fits flush and don't want to strip them.
Old Mar 2, 2008 | 09:35 AM
Default RE: valve cover seapage
Don't remember the size, if it weren't snowing like gang buster out side, I would go and look.
Carefull when you tighten them, go to snug then no more then 1/4 turn past that.
Old Mar 2, 2008 | 10:21 AM
jdelp's Avatar
Anyone else got a minute to check and see if I'm just crazy. I've got my mechanics socket set right here and can't find one to fit snuggly...unless someone stripped them before. I've tried 8-9mm, no fit and 9/32-11/32 w/ no fit. Can't find it in the Rave CD either.
[align=left] [/align]
Old Mar 2, 2008 | 10:38 AM
jkid's Avatar
Sorry, I just tried. I never realised how few 12 point wrenches I had. The closest I could get was 8mm and 5/16" and they were both a little loose (I have nothing smaller). The 8mm was a little tighter and probably would work. By the way, how many bolts are there on each valve cover? The two that I could get to were really loose, so I'm glad I checked.
Old Mar 2, 2008 | 11:03 AM
jdelp's Avatar
4 on each cover, 2 short and 2 long
Old Mar 2, 2008 | 03:24 PM
jdelp's Avatar
Just FYI for anyone else, it is an 8mm 12 point socket. Most standard mechanics socket sets don't have this size in 12 point so I need to go get one. Regular 8mm hex socket wouldn't work.
Old Mar 3, 2008 | 12:40 PM
jdelp's Avatar
Okay, got the 8mm 12 point socket. So, can I just tighten the 2 outside vc bolts on either side, or is it better to do all 4. Can I get to the inside bolts w/out removing the plenum?
Old Mar 3, 2008 | 01:33 PM
You can only tighten the outside bolts and don't get them too tight or they will leak even more.
austinlandroverbill
Apr 1, 2015 06:26 PM
yarddawg
Sep 22, 2008 03:15 AM
majrmike
Oct 9, 2007 03:13 PM
wease206
Mar 1, 2007 07:38 PM
Doss
Mar 26, 2006 06:00 PM
