Valve cover tightening
Hello all,
I am seeping oil out of my valve cover gaskets and I wanted to give them the ol' tightening to prevent it from turning into a "leak". I did some searching and I now know that I need a 12pt 8mm socket to do the job. However I was just checking to see if there are any suggestions on the procedure. For instance should I do the front ones than the rear or vice versa. Also, how tight should I make them. The last thing I want to do is strip the bolt or something when Im just trying to do some preventative maintanence. Please advise. Thanks alot.
Regards
Regards
