Valve cover tightening
Old Feb 10, 2009 | 12:18 PM
starcraft's Avatar
Default Valve cover tightening
Hello all,
I am seeping oil out of my valve cover gaskets and I wanted to give them the ol' tightening to prevent it from turning into a "leak". I did some searching and I now know that I need a 12pt 8mm socket to do the job. However I was just checking to see if there are any suggestions on the procedure. For instance should I do the front ones than the rear or vice versa. Also, how tight should I make them. The last thing I want to do is strip the bolt or something when Im just trying to do some preventative maintanence. Please advise. Thanks alot.
Regards
Old Feb 10, 2009 | 12:24 PM
Landzu's Avatar
Default RE: Valve cover tightening
As I recall its 7ft lbs tq for them.
Old Feb 10, 2009 | 01:04 PM
ghostrider747's Avatar
Before you put the turns on the bolts you might check the PCV if it is restricted it will cause oil to be pushed out of the valve covers. The PCV is cheap
Old Feb 10, 2009 | 01:44 PM
AK Rover's Avatar
The torque spec is 7 ft lbs. Torque them to about 10 and make sure to check them about every 6 months as they will work loose again. The tighter torque just delays them loosening, it doesn't eliminate it.
Old Feb 10, 2009 | 03:53 PM
Just torque them, they are very common to loosen up allowing the v/c gasket to leak.
I always suggest around 8 to 10 #'s of torque or a little more then snug.
Old Feb 10, 2009 | 04:25 PM
Just snug them up good like these guys said, if you overtighten them you will crush the gasket and cause a major leak.
Dan7
May 30, 2013 06:42 AM
Tara Elliott
Jan 27, 2012 09:54 AM
co556guy
Feb 4, 2009 08:01 PM
detcord
Sep 29, 2008 08:26 AM
dcnellie
Oct 31, 2007 09:14 PM
