Valve covers off - should I clean anything before replacing?
Old Oct 23, 2017 | 05:44 PM
samroy92's Avatar
Default Valve covers off - should I clean anything before replacing?
I am doing a valve cover gasket job on my 2000 Disco II, should I do anything else while im down there? Also replacing coil pack + wires.
What should I use to clean in and around the valve covers? There is a bit of sludge oil in there. I do regular oil changes.
Thanks!
Old Oct 25, 2017 | 11:45 PM
LandBeard's Avatar
I just started the same process. Was getting a slew of misfires then pulled the VCs and found a serious sludge situation on LH valve cover. When I cleaned my valve covers I just wiped what I could off and shot the rest with carb cleaner. While you're at it, check your PCV valve and hit it with carb cleaner.
Attached Thumbnails Valve covers off - should I clean anything before replacing?-20171024_173601.jpg   Valve covers off - should I clean anything before replacing?-20171024_173628.jpg   Valve covers off - should I clean anything before replacing?-20171024_204749.jpg   Valve covers off - should I clean anything before replacing?-20171024_205001.jpg
Old Oct 26, 2017 | 07:01 AM
shanechevelle's Avatar
get yourself a pick and poke it in all those little holes, also, spray in those holes and make sure the passages are cleaned out too.
I did this and got rid of my tick.
Old Oct 26, 2017 | 10:16 AM
LR03NJ's Avatar
Wow! What oil do you use? I would get an oven degreaser and power wash that puppy!
Old Oct 26, 2017 | 09:54 PM
LandBeard's Avatar
Last oil change was maybe 500 miles ago? I noticed the tick right before I hit Rauch Creek a couple weeks back. I had planned to flush my coolant so I thought why not oil change? Used 15w/40 and replaced with K&N 3001 filter.
I went through a few bottles of carb cleaner getting that gunk off lol
caymandrew
Jun 10, 2013 12:00 PM
flanker6
May 26, 2013 10:48 AM
innzane
Mar 20, 2012 09:55 AM
DiscoWest
Mar 19, 2010 07:54 PM
jmt
Mar 11, 2008 11:43 AM
