Very Strange Steering Problem
Old May 26, 2020 | 12:00 PM
Sundevil's Avatar
Default Very Strange Steering Problem
I have a very weird steering problem that I can not figure out. In November I replaced my power steering pump and the hoses because I had a leak. I bled the system of all the air. It drove okay for the most part but still had some rough spot when turning and the box was leaking. So this month I replaced the steering box and the rest of the components (Arms, dampener and new fluid). I jack it up, bleed the system, and take it for a driver. The system is doing great, but then I notice it stiffening up after I have been cruising for a while. I come to a stop light, idle for a minute and the power steering is back. It not does this all the time. I have bled the system a dozen times an no air is coming out. I do not see any leaks. I do not have the "power steering whine". I just lose power steering after I have been going a mile over 1500 rpms and after I stop for a little it comes back. Any idea what the problem is?? I am thinking it has to be the pump, but would like some input before I go down the route of warranting this one and replacing it.
Has anyone ever had this issue?
Old May 27, 2020 | 11:18 PM
Sundevil's Avatar
Anyone?
I am thinking its the pump that is my issue, but it is not making noise. Just out of curiosity when I bleed the system, how much fluid should come out and how fast?
Also, is there some sort of pressure regulator in the pump?
Any help is appreciated.
Thanks
Old May 30, 2020 | 09:59 AM
matt3502's Avatar
It sounds like it may be your replacement pump. I did my PSP back in October. I followed the Atlantic British video exactly. They do everything on the ground, you mention jackstands.
Here is the video: https://www.roverparts.com/resources...p-replacement/
johnkbl
Sep 21, 2023 06:17 AM
Brandon318
May 27, 2019 09:56 PM
LR03NJ
Dec 6, 2017 08:51 AM
james.martin1
Sep 30, 2014 06:33 AM
Long Haul
Jun 21, 2010 07:30 PM
