Warning Lights on dash
Old Jul 1, 2019 | 03:42 AM
woodchip2bert's Avatar
Default Warning Lights on dash
Twice in the last 4 months the manual and sport mode lights have flashed when starting and will not stop until I restart. The manual says that this could indicate an electrical fault with the automatic gearbox. On previous occasions on the forum when I have had electrical faults somebody on here has had a similar problem and found a quick fix and I am hoping the same will be this time. I have included a quick shot of the offending lights. Thanks for looking
Old Jul 1, 2019 | 06:40 AM
mln01's Avatar
There are something like 14 faults that can trigger the flashing M & S lights. Without getting the transmission codes read it's impossible to know what's at fault. That said, low voltage is also a very common cause. Check the voltage with the truck running, or go to any one of the major auto parts stores and have your battery and charging system tested for free.
Old Jul 1, 2019 | 06:44 AM
Thanks for that min01 New battery only couple of months ago and seems to charge fine but I will have it checked and also get the diagnostics checked to see if it throws anything up.
Old Jul 1, 2019 | 07:22 AM
redwhitekat's Avatar
Do you have a ultraguage to monitor voltage and temperature??
Old Jul 1, 2019 | 08:02 AM
Unfortunately not redwhitekat but will have it all checked out and thanks to you for your interest
Old Jul 1, 2019 | 09:27 AM
mollusc's Avatar
not sure if an ultragauge will read the transmission codes. a simple code reader probably isn't going to help too much but one of the loaner ones from an auto parts store might be able to pull them.
a corroded or misaligned xyz switch is another common cause of the flashing m&s lights.
Old Jul 9, 2019 | 10:20 AM
Now had the codes checked and it has thrown up the following faults......Doesn't mean much to me but I'm hoping it will to someone out there
Old Jul 9, 2019 | 11:10 AM
Richard Gallant's Avatar
Vacuum leaks in the airbox to throttle body host will toss them too, check all your hose clamps attached to that.
Old Jul 9, 2019 | 12:49 PM
mollusc's Avatar
the second error would make me inclined to pull the xyz switch and clean it.
Old Jul 9, 2019 | 08:44 PM
Extinct's Avatar
And try adjusting the XYZ Switch! Is it moisture related?
chavhater
Jul 28, 2021 05:57 PM
collector87
Nov 9, 2015 11:03 AM
wizdom
Nov 17, 2010 07:34 PM
ooster
Mar 19, 2009 03:59 PM
britishdiscovery
Jun 24, 2008 08:17 PM
