water pump gouged the front cover...now what?
Old Oct 21, 2019 | 02:33 PM
Broken08's Avatar
Default water pump gouged the front cover...now what?
my water pump i replaced 5 years ago suddenly seized. luckily it threw the belt off pretty quick so it stopped rotating, but not before gouging out the front cover housing. I'm not doing a new front cover, let's get that out of the way now. So, with this little gouging... I will clean it all up and flush it well, but I can tell there is a little bit of the lower right tip missing. I'm wondering how much difference anyone thinks that will make on the flow.
So do I
1. put it back together and go for it
2. rebuild that little corner with JB weld and reshape it
Aaaaand...attack!
Old Oct 21, 2019 | 02:36 PM
Best4x4's Avatar
Use a file/dremel to clean that corner off, then slap it all back together.
Old Oct 21, 2019 | 04:45 PM
Davis31052's Avatar
Reuse it.
Old Oct 21, 2019 | 05:16 PM
OverRover's Avatar
100%
Clean up the corner, 3M pad the center scratches and that front cover is fine.
If this was the surface of the oil pump then the outcome would be different.
Lucky for you this is a nonissue!
Old Oct 21, 2019 | 06:53 PM
mln01's Avatar
In my almost 10 years on this forum I don't recall ever hearing of a water pump seizing. Leaking, yes, even coming apart and causing mass carnage, but not seizing up. I hope you were in a safe place when it happened.
How about others here; how rare is it to have a water pump seize up? The water pump, fan and fan clutch on my truck are all original at 176K. I inspected all three when I changed the coolant a week ago and all seemed fine. I removed the fan and looked carefully for cracks, finding none. The fan clutch still feels like it's full of peanut butter. And the pump has no wobble and no leaks. I've thought about changing the pump and fan clutch proactively but I hate to ditch perfectly good parts.
Old Oct 22, 2019 | 08:59 AM
Broken08's Avatar
I've never heard of it either! And it's only 5 years old! They leak, they aren't supposed to seize!
Old Oct 22, 2019 | 10:38 AM
Broken08's Avatar
You can see the pump I pulled off. It hopped the bearings on one side and seized
Old Oct 22, 2019 | 12:36 PM
Best4x4's Avatar
I’ve seen one at a junk yard seized up! It was completely solid and locked up.
LeakyDisco
Feb 26, 2012 12:33 PM
AussieDefender
Defender
Oct 4, 2010 03:10 AM
Spencerfitch
Oct 2, 2010 12:41 AM
lipadj46
Nov 15, 2009 10:36 AM
SDinDS
Feb 20, 2009 01:06 PM
