Water Pump Housing
Old Feb 19, 2009 | 06:01 PM
SDinDS's Avatar
Default Water Pump Housing
Trying to find a water pump housing. All I can find is the water pump, I can see where it has short bolts that hold the pump to the housing and longer bolts that go thru to the block. My problem is that there is a crack in the housing, where one of the bolts goes thru, and it's leaking. For now I just patched it with JB weld, but I don't want to take a chance on it. I'm going on another road trip in a couple weeks and don't want to fix this on the side of the road, or worse yet overheat the engine. While I'm in there, I'll replace the pump, thermostat, and hoses. Any ideas where to get the housing other than a used one? AB and Motorcars don't have it.....
Eric
Old Feb 19, 2009 | 06:48 PM
What do you mean by the water pump housing?
Do you have a picture?
Old Feb 19, 2009 | 07:24 PM
okdiscoguy's Avatar
Oh crap. You are talking about the thing the water pump bolts to. That is the front cover, or timing cover as it is sometimes called. It also houses the oil pump. You are looking at about $500 if I am right.
Old Feb 19, 2009 | 07:30 PM
Oh yeah, thats what I though he was talking about too.
Yeah...not cheap, not even close to cheap.
Old Feb 19, 2009 | 07:39 PM
SDinDS's Avatar
So that housing is part of the front cover? It looked to me like it was separate
Eric
Old Feb 19, 2009 | 07:49 PM
okdiscoguy's Avatar
I am lost. Is this what you are talking about?
There is a pulley, attached to a shaft, which connects to a vane pump inside the water pump. That is the water pump. One side is open. It moves coolant throught the front cover out the hose connection. The front cover is tha part that is in between the water pump and the engine block.
Old Feb 19, 2009 | 07:50 PM
http://www.roverparts.com/Parts/ERR6815.cfm
Old Feb 19, 2009 | 07:52 PM
SDinDS's Avatar
I'll take a picture when I get a chance.....
Eric
Old Feb 19, 2009 | 07:54 PM
okdiscoguy's Avatar
This is the front cover. The long bolts go through this into the engine block
Old Feb 20, 2009 | 01:06 PM
grussell's Avatar
You might want to check with http://www.roverlandparts.com/land-rover-engines.aspx for a used one.
conmetal
Jan 14, 2013 10:16 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
AussieDefender
Defender
Oct 4, 2010 03:10 AM
Danny Lee 97 Disco
Apr 21, 2010 08:18 PM
docc109
Jan 9, 2010 01:17 PM
